greensinWA
According to the owner's manual
I have seen the tip to just add the bleach water solution to the hose, so I know that's an option.
We do not yet have this trailer and am currently in the research stage, so I can't just "try it out".
Fill and/or Sanitize the Fresh Water Tank with the Pump Using the convenient Sanitizing Valve, Hose and Water Pump, it’s easy to sanitize your plumbing system, water taps and other water using items.
1. Remove felted panel from center of aft wall of the pass-through storage bay to expose the water pump and Sanitizing Valve and Suction Hose.
2. Prepare water or sanitizing solution in a bucket, then place bucket on floor of pass-through storage bay.
3. Rotate the sanitizing valve so the valve handle is in line with the sanitizing hose.
4. Remove the cap from the end of the sanitizing hose, place it in the bucket and secure it from falling out.
5. Turn the Water Pump ON and allow the system to water system pressurize.
6. Once pressurized, open all water using taps and other water using items., one-at-a-time, hot and cold.
7. When system is sanitized, turn water pump OFF, rotate sanitize valve in line with the water pump, remove sanitizing hose from bucket and replace cap on end of hose.
I'm confused on how to add bleach to the fresh water tank. Does the pump next to the sanitizing hose feed into the tank? It does not seem like it is connected. Is there a second pump which goes from the tank to the water lines in the rest of the trailer and this pump is just for suctioning for sanitizing and winterizing?I have seen the tip to just add the bleach water solution to the hose, so I know that's an option.
