Please help me figure out if this a problem or not. The furnace works but I have found a cut wire from the thermostat.
At the furnace there is a pair of wires from the thermostat. Both of these RED and WHITE wires are crimped to the furnace BLUE wire. The WHITE wire has been cut, see attached photo.
The t’stat wiring diagram labels the RED as +12VDC and the WHITE as FURNACE.
The furnace wiring diagram labels the BLUE wire as THERMOSTAT.
The furnace BLUE/WHITE wire is not connected to anything. Labeled POWER TO THERMOSTAT.
Should this WHITE wire be repaired?
I might mention that all 3 butt splices were tucked into the squirrel cage and the -12VDC splice was worn through. The white wire may have been cut by the squirrel cage but it seems unlikely.
If you're wondering why I have the cover off – I'm painting it. Suburban's idea of weatherproof paint leaves something to be desired. Chalked up after <2 years.
I've also sent this to Alliance Service and will post any response from them as I receive it.
