Control panel beeping
TomBon
We have a 2024 Valor 36V11. The last couple of mornings we have a beeping, it sounds like it is coming from the monitor panel. The beeping lasts about 5 minutes then quites. Both mornings I pushed one of the switches on the panel then the beeping stopped, not sure if that stopped the beeping or if was just ready to stop on its own. Any idea as to what might be causing this beeping?
Hello, would you happen to have any power management devices, inverters, or Battery monitoring systems that could be setting an alarm for low voltage or another condition?
Also do you have any Solar products that could be alerting to an issue?
Have you checked your smoke alarm/CO detector and your LP detector for low batteries or other issue?
TomBon
We have the basic solar package and the monitor is reading 14.3 voltage in the battery. Checked both smoke and CO alarms and both are fine.
Given that you report it only in the morning, is it possible that your Stereo System has an Alarm feature that is enabled at a specific time in the morning?
We are hook to 50 amp shore power. The stereo is turned off and at the other side of the kitchen.
Other than the possibilities I have already mentioned, the only other thing I can think of would be a refrigerator Door open alarm.
TomBon
The refrigerator door is closed tight. I have,also contacted Alliance service and will have to wait until Monday for their response. Thanks for all your suggestions.
exps01
That's an interesting one... I had an issue where my converter tripped and wasn't working, which drained the battery and I had a couple warning beeps. That doesn't sound like the issue for you considering the battery level is full. Could it possibly be something in the pass through storage area and the sound is just traveling up? That or possibly a loose connection behind the panel is tripping something?
TomBon
Went off again this morning, right on time at 7:00 am. I think it has something to do with the DC and solar. I have to read up on how this system works. I'll keep everyone update as I learn more. Thanks to everyone.
Do you have a Solar Charge Controller panel near your switch/control panel?
TomBon
Yes and I think that is what is beeping. I have to learn more about the solar system and how to reset it when it beeps.
