So I've been doing a little investigating, and the ducts going to the bedroom from the main AC are a bit collapsed and are not blowing very strong. I have seen where others have the same problem, but haven't seen what the fix is. Any advice?
On our 24 310 one of the bedroom ducts was like that. I cut piece of pool noodle and stuck it in there. Improved the air flow.Tennis ball?
Kind of ingenious actually! That would never have crossed my mind at least.On our 24 310 one of the bedroom ducts was like that. I cut piece of pool noodle and stuck it in there. Improved the air flow.
I see that as a good possibility too! A piece of pvc would likely prevent the duct from collapsing again. I think maybe the noodle (flexible so you could follow the bends) first followed up with your pvc might be a winning combo.I like the pool noodle idea. Which led me to think a piece of flexible PVC might even be better.
Its stiffer and the walls are smoother which will allow the air to flow easier.
