Bedside Reading Lights Mis-wired?
pzcd79
Hello RVers,
I recently took delivery on 12Sep of a 2027 Delta RK234 VIN: 5TD2726VC310868.
I'm hoping someone may be able to assist with an electrical issue:
  1. The two 12 vdc reading lights and the two USB/C ports located bedside are operable only when the main bedroom lights are activated by the wall switch located in the bedroom. This makes it problematic to use the reading lights or charge your phone while you sleep since the bedroom room lights must be activated. Any insight on this issue.
All in all, we’re really pleased with the build quality and the layout of the RK234.
Thanks in advance,
Richard
You shouldn't have to do this..should work from factory. However, using a 3 port Wago connector solves your problem. Take incoming 12v wire (say red in picture)...before switch...and route into Wago. Take output (ie...yellow in image) and run to USB outlet and final wire (ie...blue) back to switch. Now USB is always on and switch operates light.
