Bedroom TV
Ocheske
We have a 32RLS an want to add tv to bedroom. What mount is everyone using and what is the size of the tv? TIA.
JWalker
We used this mount for our 24” tv. Works great.
USX MOUNT Lockable RV TV Mount for Most 10-26 Inch LED, Flat Screen TVs RV Mount on Motor Home Camper Truck Marine Boat Trailer Full Motion TV Wall Mount up to 33 lbs VESA 100x100mm Easy One Step Lock https://a.co/d/amiFyou
Ocheske
Thanks! What mounting hardware did you use? I read another thread that the mounting area is metal? What part of PA?
JWalker
1 1/4” metal screws. Drilled pilot hole first. It is a metal backer plate.
Somerset Co. PA
Emfullentar
I mounted my TV using the existing backer, but I’ve seen others attach a wood slat tv wall for a more finished look and extra support. If you're worried about weight or stability, that method seems solid. Some people also use full-motion mounts, but you’ll want to be sure everything is secure for travel.
Mounted the TV mount using 1" metal self tapping screws. Using a 32" TCL 4K Roku Smart TV.
Used a mount that the TV can be tilted down a little buyt also easy to remove to take outside to mount on a sturdy TV stand.
Dual use TV. Love Roku TV's. Use wireless WiFi or phone Hotspot for hookup! Works great!!
SKYSKIOC
does anyone know how big the backer plate is or the location of it? we have a 32RLS and want to do the same thing. wife doesn't want the tv on the dresser anymore 😠🤷
I do not, but a call to the A Team Service Dept. Might have the answer or even a print to send you.
Wondering if it could be steal and a magnet might help you find the boundaries.
