Tom S
Bedroom slide leak fix. We had an issue with the bedroom slide leaking when we had rain. What we found was on the inside bottom corner of the slide. There are two pieces of weather stripping that come together in the bottom corner. One piece is and corner that catches water that that leaks in past the side bulb seal. The other runs across the bottom of the slide. The corner piece slides inside the bottom seal and in our case were not sealed together. We added some sealant between the two pieces on top and bottom and the leak is gone. we have a Schwintek slide but cable slide are probable similar. See the attached photo.
