Bedroom slide does nothing.
Tls5150
Hello our 24 32rls bedroom slide did nothing tonight when my wife tried to slide it out. Ran out of time tonight but any hints as to the first thing to check? I’m guessing the fuse?
sheath
Hello,
It's hard to know what is going on without a little more information. Hopefully you have it resolved by now.
Check the fuse and check your battery condition. If the battery is not well charged it wont get the slide out. It may have had enough juice to put out the living room or kitchen slide but by the time you tried slide #1 or bedroom it was to low? Or if you tried bedroom first battery may just may be going bad or is just low of charge. Hope this helps.
No clue,,, it has never done it since
Well, timing is everything. We were at Sunoutdoors Cape Charles this past weekend. We were packing up today and the bedroom slide would not do anything. The controller had a green light and a flashing red lamp.
We were pressed for time, so I recycled 12 volt power and hit the little reset button on the controller. Thankfully, once 12 volt was restored the slide came in normally. After getting home,I found numerous spade connections on the controller with very little tension when you try to disconnect or reconnect them. My plan is to squeeze the spades to ensure a very tight connection on each on of them.
We did have an extremely windy Saturday night, that resulted in a lot of coach movement. Wondering it was just enough to make the issue present itself.
A mystery, But, loose connections could be the root cause. Time will tell.
Hey Bryan when you speak of the slide controller, where is it located? Haven't had any problems but I guess I'd like to know a bit more about the slide components and their location.
Lantley, on our 310 RL the controller is mounted on the off door side ceiling of our basement pass thru compartment.
I went 1 year, before experiencing the same problem. I found that the wires leading into the controller, were a bit short and needed some slack. I was able to just reverse the wires and get the slack I needed. Now I just need to flip the toggle inside, so it reflects the correct direction.
sheath
My slide system is definitely broken. It's been adjusted several times by the shop, and they have ordered several parts from Alliance. Alliance keeps pushing back asking for more tests and adjustments. Regardless I am stuck in the middle, with this back and forth and getting nowhere. I just want it fixed. It has been over two months of this and now it is crunch time. I need the RV back in the next week or two max!
