Hi everyone, I am new to the forum. We have just bought a 2024 Avenue 32RLS. The unit has a Progressive Dynamics PD4560 converter.
The dealer installed 2 new interstate lead acid batteries before we picked it up a few days ago and they showed 12.4V. After running the jacks and the fridge, the batteries dropped to 11.4vdc.
The next day we noticed the batteries weren't charging on shore power.
The converter is pushing out 14.4vdc when disconnected from the batteries. Once I hook them up, it drops to 11.5vdc. I also noticed that with the fridge running and shore power hooked up, I only see 2 amps on the positive battery lead.
When I reset the AC power on the converter, the fan came on for a few seconds and then shut off. It seemed odd when the batteries were down to less than 11vdc.
If I run my truck I get ~12amps going into the batteries and they charge.
The progressive Dynamics troubleshooting says if I have 14.4vdc then it is good. However, I am pretty sure that the converter must be faulty since i've load tested the batteries and they are good. I am wondering if there is something I am missing?
If I have to replace it, Is there a better unit I should purchase?
Thanks in advance. Cheers.
