Bathroom sink
I would suggest — if Alliance hasn't already — that they find another manufacturer or model for the "half-pipe" bathroom sink. Water does not completely drain from the front and back leaving "rings" when the water evaporates. This is not due to an unlevel condition as the water stands on both the front and back of the sink. It is not practical to dry out the sink after every use. It may be hard to see in the picture; partly because I tried Soft Scrub to clean the rings with limited success.
I understand your issue, but I will add my sink does not hold water like that.
It's possible there is too much putty around the drain which causes the drain to sit too high. Higher than the sink. As a result the drain than causes the sink to puddle water.
I'd be curious if the sink still held water if the drain assembly were removed.
I've had good luck keeping the sink clean with scrubbing bubbles bathroom cleaner
LJM
View attachment 2565View attachment 2566
I agree that sinks is terrible, mine holds water on the front and back with the coach level. Anyone know who makes a sink to fit and will drain properl. It has to be light weight.
As far as water ring is concerned…we use a water softener. I highly recommend. It will eliminate scaling when cleaning everything. Shower, kitchen sink, dishes. It will also prolong the life of the water heater heating element.
Blu Technology is the best out there. A couple of knockoffs are available but not as well made.
Blu Technology is American made veteran owned and built in Michigan. I been to the plant.
You can buy on Amazon and it ships directly from Michigan or you can order directly and they ship Fed Ex or UPS.
