Can't remember where I saw them but I have seen magnets that are very thin, almost paper thin that are capable of being rolled up. Now if I could just remember where I read that. Found this on Amazon!! There are some that are little thinner. 60mil = .06 inch. There are many others to choose from. Hope it helps!!Thank you! I had thought of magnets but thought the shades would not roll up. Will certainly look into finding a thinner magnet!
also, liked the curtains!
That is a great solution!!We have a 2025 Avenue 32RLS with the same problem but its not a real problem. The gap lets in very little light, even in the bedroom.
We are in the process of installing curtains. Not for your reason but just for aesthetics.
I have read that someone used small magnets on the roll ups. You can get the magnets that are thin and will roll up with the shade.
That will be the solution for us if the curtains still allow light in tho.
Great idee!! Tink I shall try this method grasshopper!! Hope you know what that means, "grasshopper"?I cut short sections (~3" YMMV) of black pool noodle and place them at the top between the valance and the shade. It cuts down on the light somewhat.
They've also been slit so I can place them on the bottom of the shade to keep them from banging around during travel. Need to keep as much heat out as possible.
Command strip hooks. Many different sizes. Walmart, Lowes, Home Depot, Ace.We have a shade that won't stay closed. I know I'll need to repair or replace, but for a quick repair, does anyone know of any hooks that might help it from retracting until the repair or replacement?
