380MP Converter Location
JMask
Just picked up my 380MP…. Looking through the access panels in the pass through to find the converter but cannot seem to locate it. Any ideas or info? Thanks!
Hello, welcome and congratulations on your new coach!
Have you taken a look at the fuse panel? Our 310 RL has the converter at the base of the 120/12v Fuse Panel. This is also were the switch is located to change your installed battery type if necessary.
Also, take a peek at the Alliance RV website, they have online owners manuals published there that are helpful.
JMask
I want to swap out the stock converter for my Victron. I found the breaker but not the actual converter itself
Focker
The converter is built into the breaker box. Just flip the breaker that controls the converter and you are all set. Exactly what I did on my conversion to using a the MultiPlus II.
Forum Moderator
Yep...did the same when I yanked all Alliance facotry gear (Renogy) out and replaced with Victron & Battle Born Batteries
