310RL Shower Valve Inspection
Meanjean73
Is there a way to see the back side of the shower valve to check for leaks? Wasn’t sure if the towel closet had an inspection cover?
I don’t suspect a leak but I thought it would be a good idea to check now and then.
No access panel for shower valve in the pantry on my '24 310RL. Looks like it'd be easy to make one in the back of the pantry should I need to though. Pretty sure it'd be there and not in the bathroom linen cupboard.
Meanjean73
I just checked my pantry and nothing in mine either. Thanks for the reply
Fishfnatic
I’m not at camper now but when I get back tomorrow I will-look more thoroughly. I definitely saw 2 screws and piece of wall panel. Was at Houston rv show tonight and 310 there had panel in pantry with 4 screws and panel
Well, you are lucky the access is in the pantry. I would pull out the shelves and make the entire back wall my access panel. If the back wall matches the interior, you can buy some 24" or 12" wide seam tape and make your own panel that matches your interior.
I am a bit of an animal, so this is only the opinion of a "tear it out and fix it all" kind of guy. Just don't let the water issue go unsolved. I encountered a lot of mold because of those lousy RV shower fixtures and the old style shower builds (2023). I put in an all brass residential fixture in mine. No more silicone and cheap twist on water line fittings. The pictures show, what I encountered. Because the water goes to the bottom of the wall, that is where the mold will grow first. This is why I recommend making the entire wall an access panel. I also posted the most amazing mold remover EVER!! No scrubbing and clears the mold in porous materials in 15 min.
Fishfnatic
Here is what is in mine. Have not taken out to see what’s behind . But it is waist high behind the shower hookups. I think it might be at base of shower.
mboudoin
Opening contains the valves to the shower section. Around 2ft above that are the elbows to the shower assembly. It does appear you can get to those fitting from behind the shower assembly.
