bhidalgo
The kitchen slide on our '22 310RL has a gouge in the bottom of the wood platform under the refrigerator.
We noticed wood chipping on a recent trip. Up to that point we had never had an issue with anything like this happening.
Looks like something has started protruding up from the frame into the wooden platform of the slide. Best guess I have as to what is going on at this time.
Nothing appears jammed between the floor and the underside of the slide floor from what we can tell.
And there is no evidence of anything between the floor and the platform like a screw or anything caught underneath.
Is there a way to look between the frame and the slide from the outside wheel well, or even from inside of the rig, and see what might be causing the gouge?
I don't want this issue to get out of hand. Need to fix it - or get it fixed - but do not want to mess up anything with the slide in the meantime.
But then again do not want the issue to destroy the flooring of the slide either and then we end up with a much bigger issue to deal with.
The slide operates fine otherwise.
Thanks...Bill
06/14 Update:
Ordered me an Endoscope yesterday...will use that to see if I can find the culprit.
Thanks...Bill
06/14 Update:
