Once you drain your water heater turn the bypass valve in the rats nest behind the Nautilus board and then you wont have to worry about it waisting antifreeze.Last year I winter my 310rl and took 13 gal, it filled the 12 gal hot water heater. I’ve been winterizing for 40 years and this is stupid. Why didn’t the manufacturer explain this in the manual.
Eh? The "Winterize" setting will bypass water heater tank. No reason to get behind the Nautilus panel to do that. The red handle is the water heater bypass.Once you drain your water heater turn the bypass valve in the rats nest behind the Nautilus board and then you wont have to worry about it waisting antifreeze.
Did not know that? Do you blow out your system with air first or do you just run the lines until anti freeze comes out?Eh? The "Winterize" setting will bypass water heater tank. No reason to get behind the Nautilus panel to do that. The red handle is the water heater bypass.
Yes...step one...drain water heater. Step 2...open low points and open valves (hot and cold). Step 3...close valves and blow out each valve, one at a time. Step 4...pump in antifreeze. Now, I hold off on antifreeze for the most part, as the blown out lines do the job. I do put antifreeze in all the p-traps. Now, when it was -5 degrees 2 years ago, I did put in antifreeze. Honestly, here in Central Oregon it doesn't stay under freezing for over 24hrs for many days straight. I do have a heater in my battery bay that runs on timer when temps are low.Did not know that? Do you blow out your system with air first or do you just run the lines until anti freeze comes out?
Thanks.
How long does it take to pressurize the system with your air compressor? the empty 100 gallon water tank takes a while to pressurize?Yes...step one...drain water heater. Step 2...open low points and open valves (hot and cold). Step 3...close valves and blow out each valve, one at a time. Step 4...pump in antifreeze. Now, I hold off on antifreeze for the most part, as the blown out lines do the job. I do put antifreeze in all the p-traps. Now, when it was -5 degrees 2 years ago, I did put in antifreeze. Honestly, here in Central Oregon it doesn't stay under freezing for over 24hrs for many days straight. I do have a heater in my battery bay that runs on timer when temps are low.
run your compressor at 35-40 PSI...no more!! There is no pressurization time...once you hit it with air it flows to an open faucet. The water heater is only 12 gallons, so it will pressurize quickly (put drain plug back in from step #1).How long does it take to pressurize the system with your air compressor? the empty 100 gallon water tank takes a while to pressurize?
The valve on the nautilus is broken for the winterizing, put in a bypass valve to solve the problem.I would encourage you to look up the Nautilus User Instructions for your panel. It's probably the P4 flavor like in my 310RL.
The first attachment here describes the knob functions.
The 2nd one looks overwhelming but just concentrate on one function at a time. The upper right is the "Winterize"function.
Update: I just added the User manual here. https://alliancervowners.com/forum/resources/nautilus-p4-panel.60/
ThanksYes...step one...drain water heater. Step 2...open low points and open valves (hot and cold). Step 3...close valves and blow out each valve, one at a time. Step 4...pump in antifreeze. Now, I hold off on antifreeze for the most part, as the blown out lines do the job. I do put antifreeze in all the p-traps. Now, when it was -5 degrees 2 years ago, I did put in antifreeze. Honestly, here in Central Oregon it doesn't stay under freezing for over 24hrs for many days straight. I do have a heater in my battery bay that runs on timer when temps are low.
Rider, personally I open the low point drains first and then start the blow down process through the city water connection on the panel. (Water Heater all ready drained via the anode rod and panel set to bypass)Thanks
will the low point drains need to be blown out with air as well?
