23ml improvements
Travel time
Instead of re-wiring a new heat only thermostat I decided to move the Furrion puck thermostat to see if maybe being away from the heat duct I might have better heating in the living area. It also helped to make room for the bedroom TV. A couple of more improvements to soon follow this weekend. We need to test the on demand water heater to see if it will work with the water pump.
SARGE
Did the thermostat having any wiring going to it? If so, when you moved the thermostat, how did you move the wires?
Travel time
Yes, I fished the wires that were attached to the back of the thermostat to the new location. Drilled a small hole in the wall then re attached everything. Works 100% better than original. Should have come that way from the factory. We are deep in Canada and been using heat with no problem.
SARGE
I also asked Alliance about the bedroom thermostat location. I was advised that Production has now moved the thermostat to a new location. I don't know when this move happened, but the message implied that it's repositioned in the 2026's now in assembly.
