2027 Delta 252RL grill
Jimp
We recently purchased a 2027 Alliance Delta 252RL. The outside Blackstone grill/griddle is a great unit but we prefer storage in the space it occupies. I have tried sliding the grill out of its tracks to no avail. The process on YouTube does not work on our grill. Consequently. We removed the grate, griddle and catch pan to make the assembly lighter. I removed the seven self tapping screws holding securing the unit to the RV. The unit will not come out of the door opening. The housing for the unit has square corners and the door opening has round corners making the housing too large to fit through. The only way I see to take the grill out is to remove the door and frame. I do not think this is a good idea on a brand new RV. I would appreciate help or suggestions. Thank You, Jim
First off, congratulations on your purchase.
Secondly, it is Friday night and I have just started sipping my first glass of wine, so this isn’t the wine talking.
But I am confused, admittedly I am not familiar with your model.
If the Blackstone is on a slide out and normally extends and retracts into a storage space, what is actually preventing it from being removed? Are you say, as mounted from the factory, there is no way to slide the grill out of the opening for normal use?(I understand you want to remove it to convert the area to storage)
We have friends with a Delta RK and their griddle slides in and out of a campside rear compartment just fine.
Jimp
Allow me to be more precise. The grill slides in and out fine on the track as designed. I cannot completely remove the grill from the track thus remove it from the RV. Even if I could the housing for the grill and track which is approximately 3/16” steel will not fit through the door opening. I am speculating the factory installed the grill assembly before the door frame for the grill opening. My dealer is attempting to get direction from Alliance rep. Jim
