austibd.it
Can I program or do I have to take it to dealer? Thanks so much for your help.You MPPT controller is in "float"mode. It is not programmed correctly.
I agree with Jim, programming could be an issue. If your batteries are dead, the controller should not be in float mode.You MPPT controller is in "float"mode. It is not programmed correctly.
Sorry abbout the spelling...very pissed!Te dealership said the "battery is concidered fully charged anf the controller is maintaining the battery charge. Not the case obviously.
Understand your upset, I get it is frustrating on your first trip.Sorry abbout the spelling...very pissed!
Wow, it would appear that the dealership needs to send its tech’s to some training classes. How in the world can they say that if your batteries are dead. Sorry you are going through this delima!Te dealership said the "battery is concidered fully charged anf the controller is maintaining the battery charge. Not the case obviously.
I just zoomed in on your picture, you need to check those battery terminal connections on your controller for proper polarity with a meter.( the ones OC called out with arrows)Test the MPPT controllers output by putting a volt meter on these terminals....let us know what is reads. I am assuming your RV is in full sunlight so the panels can work.
Will do.It would also be wise to check the other two terminals, to see what if anything is coming in from the panels.
I turned the fridge off prior to issues.Side note, is your genset an nps6000? If so, it DOES have an emergency pull start behind the air filter housing. I had to pull start one time boondocking and let the battery completely die. At least you could get some juice into the system to continue testing.
Also, fingers crossed for you that the fridge didn't burn up a control board with the dead battery. (I've had two bite the dust). Once you get the generator fired up, check the fridge to make sure it powers on, if not, start that claim as well...
I do not see a pull start on this generator anywhere.MPPT Controller Battery: Jumps from 3VDC to 9:VDC
PV: 44.2VDC
The Victron inverter isn't really installed upside down...is it?MPPT Controller Battery: Jumps from 3VDC to 9:VDC
PV: 44.2VDC
Well, the PV value proves you have voltage coming from the panels.MPPT Controller Battery: Jumps from 3VDC to 9:VDC
PV: 44.2VDC
