Yes. Everything has correct power and functions. Dryer receptacle has 12-2 supply.Have you tested all the plugs in your bedroom? Romex wire is not cheap these days, so I can't imagine it was connected to distribution panel (ie..it is hot with 120v) and then it just does nothing. Check outlet at washer/dryer area?
man that is a head scratcher for sure. Last ditch effort (I love a good mystery)....what about the plug in the wet bay?Yes. Everything has correct power and functions. Dryer receptacle has 12-2 supply.
Wired and working. That and the water heater are about the only thing it could reach. I have a call coming from service and if they can’t explain it I’ll just trace it to wherever it’s fed from and eliminate it. Just not something you want hanging out near the plumbing.man that is a head scratcher for sure. Last ditch effort (I love a good mystery)....what about the plug in the wet bay?
I'd just put in box and wire up an outlet. Ya never know when/why you might want to plug something in there. Like the cord to a DeWalt battery charger that you mount on the pass-through wall.Wired and working. That and the water heater are about the only thing it could reach. I have a call coming from service and if they can’t explain it I’ll just trace it to wherever it’s fed from and eliminate it. Just not something you want hanging out near the plumbing.
Jim, planned on doing that next. Thanks for the suggestion.@Emills - using a non-contact voltage tester, then switching breakers off one at a time, can you determine what branch circuit controls that wire?
I spoke to our team and this seems likely a production error. That said, could be an error in your favor depending on what circuit it's on and if you want/need another AC receptacle in your bay.
