12V Furrion Fridge problem
bbyers
All,
Just got to campground for second ever trip in 2026 Delta 321BH. Leveled and hooked up everything. All is working correctly EXCEPT the main fridge. It is stuck with a blinking #2 (off grid) on the chill setting. Will power on/off but requested temp won’t adjust. Owner manual isn’t much help from what I can see. We did have the fridge on since yesterday back home while plugged in at storage. Was good and cold before we left.
Any ideas on how to get it to allow temp adjustments would be appreciated.
All,
Perhaps, completely removing the power to the refrigerator for a minute or two might help. I am referring to a complete power removal, not just turning it off then back on.
Socal-Paul
Probably have to remove the fuse to the refer to get complete power shut down. if everything is the same it would be a yellow fuse holder in the battery area.
Was it working prior to leaving home?
Jim, Those glasses in your picture are they sun glasses or presciption? Reason I ask is: bbyers stated..........
"We did have the fridge on since yesterday back home while plugged in at storage. Was good and cold before we left."
Just giving you a hard time Jim! :ROFLMAO:
Happy Glamping! :cool:
That would mean I would have to read the entire post...not just the first sentence. :unsure:
bbyers
All,
So ended up completely powering entire rig down including unconnecting negative battery cable. Waited 2-3 minutes and reinitiated battery, solar control switch, battery switch and then shore power. After one small prayer, everything came on as should(yahoo). Been working last couple days just fine.
Really do wish the owner guide was set up more like automotive manufactures do and include some basic troubleshooting.
All,
Glad to hear that your back in business! Obviously, you should not need to do this under normal circumstances, but I am glad it worked out for you.
All,
That is a head scratcher for sure. :unsure::unsure::unsure:
Glad it is working now
