120V availability with no shore power
1.) Is 120V available in my 31RL when NOT connected thru shore power? If so, which plug is it? Or do I need to add a small inverter?
2.) Which USB's are usable without shore power?
Hi folks, you would need to have either a generator or inverter installed to have 120 volts at specific outlets without shore power connected.
I would have to defer your USB question to others on this forum, I have never investigated and documented the USB circuits on our coach.
Best regards and Happy New Year!
Upvote 0
USB plugs should all be 12v...so they work if you are plugged into shore power or just running off battery power.
Thank you both. The camera's are WYZE brand and they run of USB, so great. The 120 was for our Verizon Internet box so we could access the cameras. I'll add a small inverter box to run it. Thanks for prompt replays!
Upvote 0
