Hotrodjohn
I found the sub panel that feeds two 30 amp breakers on the main panel. If I wire to those via an inverter how does the system work? Does it require me to turn off the main and turn on the two breakers? Just trying to wrap my head around this. If the inverter has an automatic transfer switch would I not need to turn off the main?
