I am getting ready to install on our 310RL, and I am trying to figure out the best routing of the cable. So I am very interested in how you did that with yours.
Thanks!
//KMac
I wish I could get some "after" photos, but I used my expert artistry skills
to mock up some "before" photos.
- I used the included zip tie mounts to secure the cable. I placed them about every 2-3 feet on the roof, routing the cable along the driver's side of the A/C units.
- When I got to the front, I routed the cable in front of the downspout so it wouldn't interfere with drainage.
- Brought it down the side, just behind the front cap seam. That shields it from the wind pretty well when traveling.
- At the bottom of the cap, I continued underneath over to the pin box, then back toward the front storage door.
- Just in front of the storage door holder clips, I let it dangle to the ground.
This allows it to plug into the rear bumper easily, and lets me coil it up and store it in the pin box when we aren't hooked up.
Lucky for me, it was just the right length for our 372RK. If I had a shorter trailer, I'd have to think about what to do with extra slack. I might coil it up and secure it just behind the pin box. As long as it didn't drag the ground, it would be fine.
I also bought some extra zip tie mounts at Lowe's as spares, in case the adhesive fails or the mounts break.
I hope this helps! It would be so much easier with real photos, but that will have to wait a couple of weeks.
