Meanjean73
Inspecting a 310 and found a small pin hole in the Dicore around the skylight. When you press down on the area of the skylight water can be seen under the skylight.
My concern is unseen damage. The roof membrane rolls over the edge so the water may not have contacted the roof decking but may be on the inside roof panels.
My plan is to remove the inside portion of the skylight and inspect visually and with a moisture meter.
This rv is still at the dealership and no paperwork has been done so I don’t want to be too destructive in my inspection.
Easy fix for me at home but I have doubts they will fix it the way I would (removed it all and reseal).
How would you address this? Walk away?
