Wifi Ranger Osprey Installation
Bierdude
I just completed the installation of my Winegard WifiRanger Osprey to the Winegard Gateway prewire location outside the bathroom in my 2025 Avenue All-Access 23ML. The three antenna wires and the 12VDC power wires were present but I found the 12VDC wires were not hot. Searched everywhere for the Winegard ConnecT 2.0+ Wall Plate (Alliance calls it the Winegard Booster switch). It has the two switches left and right of the antenna outlet and green LEDs which power the Winegard 360+ powered antenna as well as powering the Wifi 12VDC wires. The antenna plates behind the TV, in the bedroom, and in the pass-thru storage were all just antenna plates. Was killing myself searching for the booster plate. The owner manual says it's in the pass-thru storage. After a lot of headscratching, I turned around in the bedroom and it was mounted next to the headboard at the nightstand location. Why is there an antenna outlet next to the bed, I have no idea - but whatever - problem solved. Alliance emailed me later and said it's either in the pass-thru, in the front closet, or by the nightstand, depending on the unit.
Hope this helps anyone searching as I was.
I use the Winegard WifiRanger Osprey with the ATT prepaid $55/100GB plan. I had in in my last unit and it worked fine for us in our travels.
