Water intrusion near door within the last few days 2025 310RL
mboudoin
I was doing my checks on the unit we took possession 3 weeks ago and noticed an area where water seems to have entered below the linoleum from either the door or slide. Any idea where to check? Plan today is to inspect externally today now that the rain has stopped and silicon any locations that appear to be the culprit. This is the only item we found so far in the unit that needs caring for.
Even with slide toppers, some water can enter the RV when you bring the slides in. Wondering if that is the case with your situation. Did you find this water while the slides were out or after you brought slides in?
