The wall/floor joint on the LH side, washer/dryer floor area, has pulled loose. How to you gain access to this to correct? It appears it is attached with "U" Nails only. The only item sitting here was a half case of wine....
Jim, hi, I seen a post you made on turning the closet into a possible office area and your comment on the area under the raised area, washer/Dryer floor, possibly being accessible from here?
