Vent Under Stairs 340RL
I don’t have access to my rig right now and was wondering if anyone knows if the vent cover under the stairs on the inside of the rig is ferromagnetic. I want to cut a piece of magnetic media, like you would use on the side of a car for advertisement, to seal that in warmer climates when using air conditioning.
KCAlis
is the plastic grate under the stairs nessasary does it actually do anything ?
On our 25 310RL it is the return path for the heating system. If blocked, the furnace has no direct path for return air and the coach interior will cool. A secondary benefit is that the return air warms the Nautilus panel/water heater/piping during its return to the furnace.
The AC system does not use the heating system duct/return air circuit so would not be affected by the grate being covered.
100% correct on both points. Required to heat, detrimental to cooling.
justdee
I noticed hot air coming in from that vent on a recent trip with temps in the 90's. One particular day, I had the bay door open getting the blackstone out and man, it was hot inside the trailer and with all 3 A/C's going, it would just not cool down. I was perplexed until I figured out why we had it wouldn't cool down, all that hot air coming in from the bay. I have since covered that vent from the backside with a big trash bag. I just taped it around the edges, problem solved. Cheap solution. Of course, I'll remove it when winter arrives.
I cut some foam board pretty tight under the steps and stick them in the summer time here in Tx. I have a 385 and definitely made an improvement
These are both fantastic ideas, but I'm a glutton for punishment! If I cannot find a replacement vent that has dampers, I'll go a similar route. I really enjoy fiddling, fixing, improving, and maintaining my things so not a big deal to me.
Hey Mike, keep us posted on your search. I add screen behind the grate as added protection to prevent insect entry when the basement is open for any length of time. I would love to find a dampened version as well.
