Valor 42V13 DC Lighting Zones
Valkyrie
On my power distribution panel, it shows Light Zone 1 through 4.
Can someone tell me what zone maps to what section of lights?
Thanks,
William
Thanks,
William
Hi folks,
While I don’t have the specifics of the zone mapping, I can offer this suggestion.
Consider turning all of your lighting on and then turn each breaker off(120V) or pull each fuse(12v) one at a time to determine which zone is associated with each fuse.
Most if not all lighting within your rig would be associated with a 12v circuit, so it is really about pulling the fuses vs turning the breakers off.
This way you have a definitive answer to which fuses power the zones in question.
Valkyrie
Thanks for the tip. I was really hoping someone from Alliance would respond with an exact answer, but I guess not.
I will try your method!
Thanks again!
