HI all! 2023 31T13 with single solar panel. 30 Amp shore power. Upgrading from 2 deep cell Interstate batteries to 2 100 Ah lithium. The current battery cables used to put the two batteries in parallel are 2 GA. Are those big enough to reuse or do I need bigger cables? Any other cables I need to upgrade? Also, since I don't have a disconnect for the solar panel, I assume I just disconnect the orange and black wires from the solar charge controller and cap them until everything is swapped out? Thanks for any input. Much appreciated!
