TV Mounting in 372 RK
We have a '21 372RK with the "wall" mount TV above the fire place (living room). Is anyone familiar with how the TV mounts to the wall?
While unpacking from our T-Giving trip we noticed one of the mounting screws atop the console.
I can see where the screw belongs, however it is VERY Tight between the TV and the wall. It seems the TV may lift off of a mount and I can then access the bracket to secure the screw. However that seems counter-intuitive given the bounce associated with down the road travel to have a TV mounted in that fashion.
Does anyone have any pics associated with the mount for the TV?
The mount in our 22 310RL has a lever at the bottom just left of center. Move the lever to the right and lift up on the TV. Not sure if yours would be the same.
Thanks! Similar on our unit. Did get response from Alliance Service Dept as well. The power cord was wrapped so tight around the bracket however it took a bit of "patience" to get the monitor removed.
Just curious does anyone know what the HDMI cord is routed to? The input on ours was bent due to the the tight confines of the space. Will have to wait and see if there is any connectivity issues.
