TPMS Repeater Install…
Cordless impacts are awesome. One problem, they wreak havoc on these lug nuts that have the outside casing. Most of the time splitting them.
I use a 24 inch breaker bar to try to help minimize the damage.
Very good point. And it reminded me that I need to order my Gorilla Lug Nuts. Two piece lug nuts are never a problem, until they are, which invaribly happens in the rain, far from home, at night, on a two lane road.
No. My RAM has it bulit in.
My '24 Ram also came with trailer TPMS. It has been a PITA from day one. It works about 75% of the time.
EVERY time I hookup I have to go through the menu to select another trailer and then re-select the fifth wheel before it will start picking up the sensors.
One particular sensor drops out about half the time when it does work. It may or may not come back. It was on the rear axle so I switched to the front axle and it still drops out.
Another problem with the Ram OEM TTPMS is that the valve stems are super long. I ruined one when the tire was not inflated and dropped on its face. No way you could use the flow through sensors on them. I have shorter ones and plan to swap out when I get new rubber.
Because of these issues I purchased theTire Minder Smart TPMS. Its display is my iPhone and also displays on CarPlay. It has worked flawlessly and also displays the tire temperature.
To answer OP's question – I wired it to a basement light and screwed it to the basement roof.
rdrew
I wired in a Tire Linc Pro on my Delta. Behind the water pump panel i found a 12V Bar with an empty lug and caught a ground off of the inverter prep box......only had to run about 12" of wire. Easy install and works like a charm.
You will probably find that the battery box has on opening at the bottom for drainage. Ran the wire out that to the bottom of the RVF and connected directly to the battery. We are always hooked to shore power and the draw is probably next to nothing anyways. Solar takes care of while on the road so never worried about it.
