Tow vehicle for Paradigm 310?
Austin Alliance
I would like to ask all Paradigm owners of what their thoughts were on towing a Paradigm 310RL with a 2022 GMC 2500HD Denali. The GMC tow #’s are as follows:
Max Pin Weight 2490lbs
Max Tow Weight 16690lbs
Cargo capacity 3300lbs
Reason I asked, salesman had my wife talked into a Paradigm 310 and he swore up and down I could tow it no problem… I told him I was very leery of that and felt more comfortable with a 1800-1900 pin weight and GVWR of trailer at 12-13K..
Any thoughts? Thanks
See signature below for my equipment. IMHO a 2500 is not enough truck to pull a Paradigm. I probably should have bought a DRW 3500. 🤷🏼‍♂️ You will undoubtedly get comments like "I pull with a 2500 just fine" but my opinion is it's not enough..
FWIW — The pin weight of my 310RL loaded is 3,180 and I have removed a lot of stuff from the front storage and pass through bays.
My rear axle is 240 pounds overweight but under the tire load rating. I do have a rather heavy hitch and weighed with a full 40gal aux tank.
The weight of our 310RL is 14,460 with only about 20 gallons of fresh water. I am well under GCWR so putting more water behind the axle will actually help lower the pin weight.
exps01
I think you probably could tow it, but probably not the best idea. You'd probably be pushing the payload capacities. Of course people tow some huge trailers with 3/4 ton trucks that have no business towing them. I have the 3500 DRW truck and it's super stable and no issues. I unfortunately don't have the weights yet (had an issue at the scales when I went). It's definitely an amazing rig though. Not sure if you'd be interested in upgrading the truck. I remember the Irene Iron Travels youtube channel had a 3/4 ton truck with the 29MK paradigm and it was overweight, so those trucks are probably a little too undersized for them.
JWalker
Pin weight will be your downfall with the 2500. The payload will be printed on the inside door jam of the driver side. It's possibly 3000lbs.
We have a 2023 GMC SLE. And the payload is 3280lbs. So you're Denali probably has a few extra features, which adds weight and takes away payload.
Austin Alliance
Mine is 3300lbs, I just don’t feel safe pulling something so heavy with a 3/4 ton truck🥴
Austin Alliance
Thanks for your insights, I totally agree. I don’t know why sales people make up stories to sell a trailer putting our safety at risk🥲
Austin Alliance
I totally agree with you👍🏼
JHC
I am looking at the same trailer. My TV is a 2024 Ram 3500 SRW, payload of 4251. Just had the truck weighed:
- Steer - 5220#
- Drive - 3260#
- Gross - 8480#
Add in the hitch at 150# and my available payload is 3670#.
Do you have a generator in front? I see you removed gear from the front storage and pass through.
So if your loaded pin weight is at 3180#, I am encouraged my truck can handle the 310RL.
- Steer - 5220#
- Drive - 3260#
- Gross - 8480#
I do not have a generator and the stuff I removed from the front totaled about 200#. I moved it to a UWS brand aluminum tool box on the 310's trailer hitch which probably unloaded the pin >300#. The Demco Autoslide hitch I use is around 450# and the 40 gal aux tank is pretty heavy too. Without that aux tank I'd be back in range but I still think a DRW truck would be a better tow vehicle for me, we just couldn't stand sight-seeing and parking in a DRW.
There are some that tow a Paradigm with a short bed and a conventional hitch but I did not feel comfortable in sharp turns. If you have a long bed and use a conventional hitch that will help with weight as well. Remember that Paradigms are 8' wide and with no concave features on the nose.
Unhitched and fully fueled up, hitch and only a driver my Ram is 5,300 Steer + 4,200 Drive.
We initially had a 2024 Ford F350 super duty SRW. We thought with the lighter weight and shorter length it would be ok on a 2024 Alliance Paradigm 310RL. But after a few rides we decided with our prior history of fifth wheel towing to go back to the standard.
So we purchased a new 2024 Ford Super Duty F 350 dually with the H.O.engine and a 4.10 rear axle. Big difference. We had already previous to this changed to the MorRyde pin box, which we have used in the past on other fifth wheel units.
I would never pull any fifth wheel with a short bed, ie 6 ft unless you have a slider bed hitch.
This is really the best approach. If you are even remotely concerned about weight and cargo capacity your set up is marginal at best.
If you are scratching your head because you do or don't have a generator you're cutting it too close.
Paradigm's are not light weight units. Additional margin and capacity is desirable, particularly if you travel nationwide.
Simply put get the long bed dually and be done with it vs. constantly reviewing the parameters and sweating each item you put into the trailer or the truck.
Oddly enough cost of the truck is not the issue. A dually is comparably priced to a 1 ton SRW.
Prior experience with a heavy trailer is often the deciding factor.
A combo that is within all of its towing parameters always performs better that a combo that is within some of its parameters.
