Ramjetr1960
Hi...i have the same problem with me 29rl...rear is low and nose is high...where did you get your wheel and tires?Just finished installing 235/85R16 tires with new wheels on our 29RL and Sumo springs on both axles. I also found that all the Avenues were to come with the 235/85R16 tires and ours did not! Been a concern since picking up in May as our rear jacks were 5" off the ground when hooked up and the bed clearance at the rear of the bed was 6" as well so "NO" room there to lower it. Stock Chevy 2500 Duramax. Got a close friend with a tire store so got tires and wheels from him, installed and did some measuring and all looked great with the 235/85R16. Reread the Avenue owners manual and it states "we use 235/85R16 on all Avenue trailers". needless to say my rig now tows very close to level with "8 of clearance on the rear jacks 7 1/2" of bed clearance (i could and may drop the 5th wheel 1 bolt hole" after really towing a distance rather than a short drives for checking things out.
My new wheels/tires worked as expected with no issues so thought i would share. The Sumo springs were just an extra add on as i was under the trailer anyway and have heard great things they do for the ride. Thanks, 7ACmike
Roger
