Teflon tape required?
KCAlis
I’ve identified which black plastic fitting is leaking on the back of my Nautilus panel. Of course it’s in the middle of all of the fittings and all but inaccessible.
I don’t see any way to fix the leak without disassembling many of the cold and hot connections. My fear is fixing one leak and creating others. I have teflon tape and slip-jaw pliers so not a problem material or toolwise.
Are the connections NPT or flare? Does anyone know if the black plastic threaded fittings require teflon tape to seal? (They are all taped now.)
KCAlis
I had that niggly feeling that Teflon tape wasn’t required. Thanks. And thanks to both of you for wrench suggestions.
I need to pick up a wrench and spare cone washers before I take up leak mitigation. Methinks I will have everything on the back of the Nautilus panel torn apart before I’m done!
KCAlis
Finished reworking all 12 connections 2 days ago. I put all 12 back together with santoprene washers and NO teflon. One fitting seeped on startup. A little coax with my slip-joint pliers changed its mind. 👍
I think an added benefit will be improved flow! The first fitting behind the garden hose inlet connection was half restricted by teflon crossing the opening! It was actually stretched tight. I tugged on it and caused the slack. Sloppy and preventable workmanship.
I took the opportunity to replace the water heater anode. 16 months old and all but gone. Hopefully no tank corrosion, yet!
