Slide outs and lights
steelerdog
Good morning! I have 2025 Avenue 32RLS ans am having an issue with the lights and slideouts working while hooked up to 50amp service. It seems there is no power going to either. All the other electrical items work. They will run off of battery power but not the electrical service. Checked the main breaker panel and the sub panel everything looks to be ok. Any help would be appreciated.
Hi folks, I am not sure that I fully understand your issue.
The slides and lighting work off of the 12 volt Dc system.
The act of plugging into the 50 amp service should activate your converter, which in turn would charge your 12 v battery.
Ensure your 12 volt master disconnect is on when plugged into the 50amp.
The converter itself, will not support slide out operation, the battery is necessary due to the amp draw.
Additional detail’s might help get to the bottom of this. Do you have a standard electrical system?
Is there a genset and transfer switch involved? Inverter?
