Slide in bed use 310RL question
rshankel
Does anyone know if on a 310RL and with a queen bed, can you use the bedroom without the slide out? I can't find any dimensions shown with the bed slide in.
I do not own this yet and haven't seen one in person either!
Thanks,
Roy
If you go to AllianceRV YouTube channel and click on Playlists then WhatchaKnowWednesdays, you will find the 85 videos. A very good collection of FAQ videos.
While not specific to your model One of those videos pertains to using the bed with the slide in
rshankel
Thank you, I found it!
I think it said not to sleep on it with the slide in? Because the bed has no support at the foot?
I don't think it sad don't do it. But it said beware the end or foot lack support so avoid putting your weight in that area.
More or less do not sit on the foot edge of the bed. OK to use with caution
rshankel
I tried to find a 5th wheel without slides because I don't like extra holes in the camper and the problems slides present mechanically, but the only company I found was ATC and they are too costly!
I pray that the 310RL will be low maintenance?
Thanks,
Roy
it is tight it there with the bedroom slide in. Is there a reason you would not put slide out while spending the night?
If you are in a rest area or parked along the roadside where opening the slide could present a hazard you may not want to extend slide.
Also if you are remaining hooked to truck and not quite level you may avoid opening slide. There are times when not at a camp site that extending the slides creates an issue.
Being able to use bed with slides in is not ideal but is a desirable option to have
