Running a CPAP on 12 volt power?
My Paradigm night stands electrical are 120. When power goes out I cant run my CPAP?
Has anyone figured out how to run the CPAP on 12volt power?
please advise?
Thanks
please advise?
Thanks
Rider, I have no experience with CPAP machines.
Have you investigated if 12 volt models are available?
You could consider a small inverter, rated to power your machine
You could carry a small “Power Pack” with you.( all in one battery/ inverter) For Example a Stanley Fat Max or similar (many types are available)
And as you know, you could fire up that genset of yours if rules and conditions allow.
RoadJunkie
I ran a 12 Vdc line to the nightstand with a conventional cigarette lighter port to power my CPAP. However you may need a DC to DC converter as many newer units run on 24 Vdc. But you can also use an inverter while assuring it will handle the current of the water heater in the CPAP.
I have fired up the genny more than once to run my CPAP, just thought with the new lithiums I could run it of the batteries and not have to make all that noise?
JMomof3
My CPAP has a 12V power adapter available as an option. I use a ResMed AIrSense 11. I purchased the 12V power cord on Amazon. My Paradigm doesn't have any 12V plugs, so that isn't going to do me any good. I do boondock with a portable power station and use the 12V plug then.
please advise?
Thanks
Midnight,
From a former CPAP user. If you can, check with your ENT Dr and check into getting the Inspire device. It is awesome! No need for a connection agt all. It runs from self contained battery (10 yrs) and is controlled by an hand held fob to turn it on, pause or off. Google and check it out. Well worth it!! Insurance does cover it!!
Creek Jenkins
We boondock a fair bit syI bought the 12v power supply for my Resmed cpap for around $30 and then tapped into the slide power wiring under the head of the bed of our 310rl. Figured I wouldn’t be running the slide and the cpap at the same time. Installed the 12v socket near the outlet and it works great. Probably $40 total investment.
RoadJunkie
Midnight,
From a former CPAP user. If you can, check with your EWT Dr and check into getting the Inspire device. It is awesome! No need for a connection agt all. It runs from self contained battery (10 yrs) and is controlled by an hand held fob to turn it on, pause or off. Google and check it out. Well worth it!! Insurance does cover it!!
Inspire does not work for everyone, particularly central Apnea. Just as a data point, my sleep therapist thought they were a good idea when they were first introduced, but cooled on a recommendation. I'm really glad you've got a solution that works for you!
Yes you are correct. That is why they have you gfo to an ENT (not an EWT) to check throat structure. But they do work. IT does take a little time working with the sleep therapist to get the electric sign waves adjusted to the correct pattern. If your sleep therapist is doing all this, that could be the problem. Every time I was with my sleep therapist, a trained Inspire Technician was doing the actual adjusting and ensuring that the device was doing what it was supposed to. If your satisfied go on ya, I just know that is an awesome piece of equipment and makes sleeping much more enjoyable and with piece of mind that your heart isn't going to stop. I am a firm believer that sleep apnea is a killer. Many people die in their sleep because of heart failure and chances are they had sleep apnea.
It is also MUCH easier with a fob that you just click and turn it on and go to sleep. No noise, hose or mask.
anyway....Happy Glamping!!
Is that the implanted device? Like a pacemaker? 😳
George, Yes, its about 2" in diameter placed on your right side right below your clavicle. Little wires run up to your neck to a muscle nerve and is attached. It sends a signal every 4 sec to that muscle and it make your neck contract and keeps your throat open for breathing. There is no pain pre, during or after. I will say tho that if you forget to pause it and try to talk, you sound like a drunk, your tongue just doesn't work right. Gotten many laughs from that but I LOVE it!!
I’ll just keep my CPAP?
one wrong move on that other thing and you will be doing the electric jig! ⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️⚡️
Sorry, you are so wrong. First there isn't enough voltage to "light you up". It is very very small charge.
You for sure have not even looked into it. Thats OK.
Thats why they make CPAPs for peolle that love them.
Don't say you don't, cause if you didn;t you would embrace something like Inspire.
Happy Glamping!
Happy Glamping!
Love my CPAP been on it 20 years.
i was just playing
Each their own 🎩
Roll On!
