Roof vent
Mvice
On my 2024 32RLS there are 3 vents on the roof. The one in the bathroom, the one over the stove, and then there is one between the pantry/coffee bar and the island. It has the manual knob to open and close but for the life of me can’t find a switch to turn it on. There is a blank switch plate on the ceiling right next to the fan but it says something about tv wiring. Anybody have any ideas?
Any chance it is controlled from the heater/AC controller? We only have 2 fan and have the standard switch, shown with blue arrow
Jwtsg
Good morning Mvice,,,not Familiar w your unit layout. But does either your pantry/ coffee bar or island have a separate light switch for spot lighting in or between those locations?
On our 2023 Paradigm 382RK our 3 rd fan (1/2 bathroom) runs off a switch that has SEPERATIE controls in one switch plate for occupancy sensor,,,basin accent lighting,,,ceiling lite,,, & fan. To operate ours it will only operate if we turn off the occupancy sensor and turn on the overhead ceiling light,,,then the fan. It receives its power from the ceiling light,,,different layout for sure but your fan may have a similar power source ??? Took us awhile in our PDI for us to figure that out,,,salesman had to get service mgr involved,,,,,Hope this helps,,,,good luck,👍🍀,,,,am certain other members w your model will weigh in as well! 👍😋
Mvice
Thanks for the replies. Oregon, the answer is no to the controllers. the only switches I have above the panel are for the thermostat and kitchen lights. And JWTSG, I will look for switches where you said but I would still have get a ladder or at least a stool to open the vent being that it is at the highest part on the ceiling. It’s just strange.
Jwtsg
Mvice,,,sorry got distracted & just got back from town, Meant to send pic w first reply,,,,here is pic of our setup,, bottom 2 switches turn on basin accent lites & 1/2 bath fan lite. Upper cluster turn occupancy sensor on/off. Upper rh turns main ceiling lite on/off; LH switch turns exhaust fan on/off.
fireman0175
The third vent above the coffee counter is purely manual. That means you have long arms or a ladder to open it and close it. It is done that way I guess for the easy installation of a third AC unit. We just leave ours closed as the the others work fine for normal usage.
