castore357
Are there any videos on removing/replacing the garage door key assembly? Changing all locks. Would like to have less keys.
I will send you a PM, it is very easy.Sorry. Yes, Ramp door. Ty
Sent you a PMFocker would you mind sending me the info as well?
TySent you a PM
If your key turns and nothing happens you either have a fuse / electric issue or the release hooks on top of the door have an issue. I would work on that problem before taking on the lock change. Have you opened the ramp door with the release pull on the top interior to start a diagnosis?I wouldn't mind the info too please. Just picked up a '22 42V13 yesterday and I know the dang thing worked at the stealership. Now the key just turns and doesn't do a thing. I'll need to get in there anyway. TY in advance!
UGH!! 🤪 it wasn't explained to me that it was electric-driven... I had everything off, and yes I did open the ramp from the release pull in the garage. When the dealer did it the battery was on. Problem likely solved when I go back out to see it!! Thank you!!If your key turns and nothing happens you either have a fuse / electric issue or the release hooks on top of the door have an issue. I would work on that problem before taking on the lock change. Have you opened the ramp door with the release pull on the top interior to start a diagnosis?
