rickybobbie
I have a Valor 43v13 and when trying to open the ramp door from the key outside I can hear the actuators trying to pop when turning the key. About 1 out of a hundred times the passenger latch will release but the drivers side never does, I checked for obstructions and sprayed the latches with WD-40 when I was able to open door from the inside yellow strap I have leveled the RV and it made no difference. It is also only about 30 degrees outside so I wonder if that is affecting it. Anyone else run into this and have any solutions
