We recently purchased a 2025 310RL and I'm in the process of expanding batteries (24v system) and adding inverters to allow more off grid adventures. As I'm laying out the plans, I wanted to get some feedback on a couple questions I'm wrestling with.
Question 1: Location. I keep going back and forth between putting the batteries in the "equipment" space behind the pass-through wall and putting the components on the wall in the pass-through storage or putting everything into the front/nose compartment areas. By going to the nose, it gives me easier access to the batteries if I need to sperate/balance them (using 12V batteries in series) and leaves the pass through completely open. The downside is it forces me to pull the AC power up to the nose and then back to the panel vs just a 12VDC run up to the front factory distribution bar and I lose some storage space. Curious what others have done and if you have any pro's / con's to share?
Question 2: I'm planning to use Victron components and have been looking at the Multiplus II 2x120 and the Quatro II 2x120. Basically, both are the same inverter/charges with the addition of a second line in on the Quatro. I was thinking I could use this 2nd line in as a charging source while towing by using the 1500watt 120v AC output in the bed of the truck (F450 with the generator option). By using the second inbound line I could limit set the power pull from the Victron unit and not have to remember to do it every time I moved. Since I have a 24V battery bank this seemed easier than DC to DC from the truck. I'm curious if others have added a plug to the nose of their trailers and used the AC out from the truck to charge while driving?
Thanks for your input.
