Outlets not working
cstrauss
That sounds like you might be missing one leg of your 50 amp.
That could be the pedestal, your cord, your shore power connection to the coach or even a bad connection on the transfer a transfer switch if equipped. Or at the breaker panel in the coach.
An easy check would be to see if you could talk a neighbor into trying their pedestal as a test.
Just switched to the 30 AMP outlet and everything works so it must be teh Campground 50 amp that is bad
BryanValRox,
Not sure you would need one of the above if your surge protector s worth anything. Mine tells me right away if the electric is not perfect.
No need for diplicate devices to tell you the same thing.
BryanValRox,
Flyer, understand you point 100%. The method to my madness is that we get to the site and get either pulled in or backed in. Then, the first tote inside my basement door contains my wheel chocks and this tester. After chocking the wheels, the tester gets plugged into the pedestal for validation of the service. This way I can validate the electrical before dragging my cord or anything else out for that matter. If all is well at that point, we start to unhook and set up.
Also in our case we have an onboard surge protector, so I would not be able to validate before plugging the cord in.
I was just sharing what works for me and offering a suggestion for consideration.
One thing is clear , we all have different reasons for what we do, and there is no one size fits all solution.
Hope you have some nice trips scheduled for this season.
