Campingsxs85
My Wife and I just purchased a new 2022 Alliance Valor 42V15 with a Onan 5500 Generator onboard. Yes, it is a brand new 2022 we picked it up in Billings, MT. We live in the Midwest so it's hot and humid a majority of the summer. We are not new to camping this is actually 4th camper but it is our 1st Toy hauler and since we have purchased it back in June we have pulled it several destinations totaling roughly 4,000 miles in just a few months. We have aspirations of Boondocking in the Mountains and riding our SXS out of a remote location. But until I can keep the Generator running I don't feel comfortable taking that leap yet until I can keep it running. Currently the Generator has roughly 35hrs on it and the majority of the hours are on it from troubleshooting. It will run anywhere from 2-3hrs in a shop setting right now. When we first got the camper 1/2-1hr might of been about it then it would shut down.
So far what I have done to the unit is the first break-in oil change at roughly 20hrs. I have put a new fuel pump on the Onan 5500 with a new fuel filter. I have added a second Low Pressure fuel pump next to the tank to supply the fuel pump on the Generator unit which has helped tremendously. I added the titanium spark plug wire wrap around the fuel line in the Generator compartment to try to keep the heat down on the fuel line (Vapor Lock). I have wrapped the fuel pump under the unit with exhaust wrap to try to keep the heat off of the fuel pump to keep it from shutting down.
I have tried to run this unit while driving down the road and it seems to me like about 2 hours is the most it has ran. Our last trip was to Galveston, Tx a couple weeks ago and it was upper 90's low 100's the entire trip and we could not keep the unit running. Coming home the last day it was considerably cooler probably 75 degrees and it ran for about 4.5hrs with 2 A/C's on with no problems. Which leads me to believe that this entire issue is a Hot Air Recirculation issue since the cool air intake and hot air exhaust is all on the bottom of the unit.
Has anyone has this same problem with the Valor or any other 5th wheel camper for that matter? I think my next step is. I am going to Duct the Hot Air Discharge out the same side as the generators exhaust (Driver Side) to try and get the hot air out from under the camper to try to prevent hot air from entering back into the cool air side.
Any thoughts or suggestions would be appreciated. Thanks!
