Mine has solar panels and the renogy was showing it was charging, however the battery heating pad malfunctioned and stayed on causing the battery to shut down or lock out (not accepting a charge). The monitor inside was showing a couple codes but the main one was an overheat code (08 I think). Some Renogy Smart Lithium 100ah batteries have built in heating pads (actually inside the battery between the cells) and some come with a heating pad underneath the battery. Not sure about the internal ones but you can trace the wires from external pad and unhook if your monitor shows overheat code.42v13, batteries are charging from solar, but the renology converter has no power. Rv is in storage, worked 3ish weeks ago. It has been on, was keeping fridge cool. It has been really hot the past week, is it possible that the converter shut off due to heat?
