New to Alliance and Avenue 32RLS
Hello All, we just purchased a 2025 Avenue 32RLS. Went over to inspect last Tuesday. Got there at 10am. Unit was ready for inspection in the breeze way with water and electric. I took a light out and started in the LR. Looked at joints, flooring, cabinets interior and exterior under light. Found three small things after 2 hours of turning twisting, sliding touching interior and exterior. Was very impressed with the workmanship. Did find the hold down brackets for the blinds over the kitchen sink were not spaced properly. One side would was about an inch from touching the blind. Fixed on the spot. A corner of the living room slide flooring when slide out all the way would wrinkle a little. Heat gun and some pulling under the support post fixed it.
How has everyone else who has a new 32RLS liking theirs? Any problems that I could be able to fix before they become a problem? So far we really like the lay out. Was looking at a used 2025 Brinkley but was priced out of our range. Identical lay out! Think we will be happy!
Happy Glamping!!
Tls5150
Check the closet doors and re secure them, make sure your converter is switched to the type of battery you have.( ours was set to Lithium and we had lead acid)
Make sure the shower wall that backs up against the bedroom isn’t pulling away
( dealer had to re secure ours) make sure the awning over the door doesn’t hit the other slide( dealer had to move ours over about one inch) double check the trim( ours were pulling away from the walls)
Turfengineer
Congrats and welcome!
Our 32RLS had some issues with the bed slide. The bed frame had broken and resulted in the schwintech slide failing. A local dealer fixed this, but I restructured the frame later.
We had a leaking window on the campsite slide that the dealer said the replaced, but it still leaked. This was corrected at a factory service appointment.
The closet door and door frame fell off. I noticed this during inspection and the dealers solution was to use more staples. I later fixed this with screws.
Love our 32RLS. It’s our home away from home.
Tia5150, You know i would check my converter but have no idea where it is. It is not in the forward storage area with the disconnect switch for battery and solar, Other than that, the batery is located there and there is nothing else component wise. Your help is appreciated!!
2 Allies
It will be behind your breaker and fuse panel. Check the owners guide online for what the switch looks like. Check out the Paradigm Owners Guide on the AllianceRV site, it shows it pretty clearly.
