New Linen touch-up paint color code/availability
Bierdude
We recently took ownership of a 2025 23ML in the new Linen cabinet color. I contacted Alliance for the paint color code and availability.
It is Valspar Interior Ultra Eggshell in a custom color from Lowes. My local Lowes was able to mix a quart for me from the attached paint can color code sent to me by Alliance.
justdee
Steve, this is much appreciated information.
I just had to fix the bathroom door. It had come off the rear sliding mount and I had to remove the flat trim piece that conceals the slide rail. Which meant I had to use some staples to remount the trim piece and thus I have some exposed staple heads. I was regretting not taking that trim piece to HomeDepot before I reinstalled it. Now I can just go and get a quart.
Thanks!
GWBodkin
Just to keep everyone updated, Lowe’s has changed their paint codes. While they have a way to cross reference the old code system to the new one, their staff have not all been trained in that regard. Also, know that the paint codes change based on the size of the can of paint. As I understand it, it’s based on the amount of base color preloaded in the can. The employee I was working with didn’t correctly input the correct code as I was attempting to get a pint vs. a quart. That said the original color presented to me was a mustard looking color. So, I just had the staff member mix a quart for me; the color was perfect then.
GWBodkin
Just to keep everyone updated, Lowe’s has changed their paint codes. While they have a way to cross reference the old code system to the new one, their staff have not all been trained in that regard. Also, know that the paint codes change based on the size of the can of paint. As I understand it, it’s based on the amount of base color preloaded in the can. The employee I was working with didn’t correctly input the correct code as I was attempting to get a pint vs. a quart. That said the original color presented to me was a mustard looking color. So, I just had the staff member mix a quart for me; the color was perfect then.IMG_4037.jpeg
