Moving Rig
bhidalgo
Hi All,
Our '21 310RL has been parked in an RV park since May of this year while I was living out of it part-time due to work. The part-time experiment has ended, and we will move it about 100 miles north to a storage lot in the next 2 weeks. (From the Orlando area to St. Augustine)
Besides topping off tire air pressures, emptying tanks and possibly water heater, do you have any suggestions on what else I should do to the rig before we move it? I will be checking the suspension and weld joints, as well as slide gaskets, for any apparent issues. The rig has never given us a problem on the road since our uncommanded entry door opening issue was fixed.
We are going to do a pre-move once-over tomorrow to try and get most things done to it prior to the move.
Thanks in advance...Bill
Hi All,
Hey Bill,
Sounds like you’re off to a good start! Maybe check a few more things?
- Make sure Slide Tops are cleaned and free of debris
- Batten down the inside real good. Living in it causes stuff everywhere and it can go flying.
- Oil King Pin, Oil Hitch, oil male and female 7 pin with WD 40.
- Truck Tire Inflation.
Drive Safe
