motion lights in the basement
Terry M
The small square motion lights and the light strip in the basement stays on constantly. .covered motion sensors up and still they stay on. Anyone else have this problem before I take it back to the dealer?
Long Islander
I'd be willing to bet that the motion sensor is broken and/or wired wrong. We noticed not too long after we picked up our trailer that the pantry closet light never shut off. So one day I took a look at the wiring and it didn't make sense to me (I'm an Engineer), so I called Alliance and they sent me a diagram which proved that it wasn't wired right. So I took it all apart and rewired it correctly (based on the diagram that Alliance sent me). That's when I discovered that the sensor was broken and would never turn the light on. I have to assume that the tech in factory who did the original install also realized that the sensor was broken and rather than replace it, he ran another 12V power lead over to the sensor which basically bypassed it so the light always stayed on. Alliance sent me a new sensor and I wired it up and it now works fine.
I tried and failed to find the wiring diagram (actually a picture) that they sent me. If you call Alliance customer service I'll bet they can send it to you as well.
Meanjean73
My 2024 has a 3 position switch. I assume one is on, motion and off?
Those lights suck! Mine did the same thing. It was wired wrong.
i rigged up a puck lite system and light up the bay with the touch of a button
Headed West
My 2026 25RL has a pantry light that won't go out. I did not notice the light being on when I got it at the dealer just a few days ago. Hopefully just a failed motion sensor.
SKYSKIOC
I just disconnected mine and hooked up a switch. got rid of the motion sensor and works like a champ
Capn_AJ
Our pantry motion sensor was not working and the light stayed on 24x7. I contacted Alliance today and received the solution. The blue wire is connected to the wrong white wire. My motion sensor is connected to a string of lights running up the side wall of the pantry. The blue wire is the ground connection to the auxiliary lights. Once I swapped the blue to the other white wire, it started working. I have attached the diagram for your reference.
  • Motion Light installation and wiring.pdf
