Hi
@Gleninaz - few of us on this forum are electricians are HVAC techs. So please be careful with the assistance you receive here and treat is as ideas / guidance and not as a how-to. The how-to is on you to know or learn or hire-out.
That said, I took a look at the manual for one Mr. Cool mini-split and gleaned the info below. It's doubtful I correctly guessed your model number, so use this info carefully and cross check with what you actually have and the manual that came with it.
A 115-120V unit will require 3 conductors of the correct wire gauge. Those conductors will connect to your power system's line, neutral and ground. Generally speaking, all 3 can be found inside the AC panel box:
- L (line) will come from a breaker
- N (neutral) will come from the neutral bus
- G (ground) will come from the ground bus
Use of the proper AC wire gauge is critical for all AC wire circuits. Below is a table from a Mr. Cool mini-split manual showing the minimum wire gauge to be used based on the size of the mini-split model.
I urge you to have a conversation with Mr. Cool customer support, detailing your installation plans with them and let them guide you on aspect such as:
- Mounting ideas of outdoor unit
- Ventilation idea of outdoor unit
- Wire type, gauge and jacket/conduit type for outdoor unit
- Circuit breaker type and rating for outdoor unit
